To register for an Internet.com membership to receive newsletters and white papers, use the Register button ABOVE.
To participate in the message forums BELOW, click here
http://justlinux.com/   Tue, 09-Feb-2010 16:04:55 GMT
         internet.com
Go Back   JustLinux Forums > Community Help: Check the Help Files, then come here to ask! > How I Did It!
How I Did It! Got a How-To/Tutorial/Guide you wrote? Post it here.
Reply
Thread Tools Search this Thread Rate Thread Display Modes
  #1
Old 01-21-2004, 01:26 PM
hlrguy's Avatar
hlrguy hlrguy is offline
Mandriva 1 on a T3640
86 the annoying delays from ad servers
Overview...noticed that Linux today uses, started using klipads.dvlabs.com as a new ad server. This server demands a reply from the client machine, for a full 5 minutes before timing out, before the page is allowed to load. I won't open up my firewall to allow for the ack from my closed ports, so started looking. Reference in thread...
http://www.justlinux.com/forum/showt...hreadid=120746
Did a search on 'klipads dvlabs' in google. Came accross this...
http://everythingisnt.com/Hosts
# This Hosts file has been altered to block ad servers.
127.0.0.1 klipads.dvlabs.com
Basically, you just add the annoying ad servers to your hosts file, incorrectly telling your browser that the IP is local, it doesn't go to the web server, doesn't stall the page, and poof, linuxtoday is navigable without opening my firewall.
I find, more and more, that web pages require MANDATORY ack from the server port queries, or the pages load really slow or fail to load.
I am still investigating whether there is any security problem with adding these addresses to your hosts file.
Thoughts?
Note: This post may be deleted, because ads are the staple of content providers, however, demanding a hole in a firewall to be able to surf web pages is, in my opinion, simply wrong ad should not be tolerated. For the pages that use these ad servers, it is simply use one that doesn't require a security breach, or deal with people not coming to the site.
hlrguy
__________________
Were you a Windows expert the VERY first time you looked at a computer with Windows, or did it take a little time.....
My Linux Blog
Linux Native Replacements for Windows Programs
Mandriva One on a "Vista Home Barely" T3640 E-Machine runs great.
  #2
Old 01-21-2004, 01:36 PM
ph34r's Avatar
ph34r ph34r is offline
HAL
No issues, as long as you don't want to surf to that particular domain. Even better if you use Mozilla is to use the userContent.css file to control display of images based on URL or path...
 * This file can be used to apply a style to all web pages you view
 * Rules without !important are overruled by author rules if the
 * author sets any.  Rules with !important overrule author rules.
 * turns off "blink" element blinking
blink { text-decoration: none ! important; }
 * hides many ads by preventing display of images that are inside
 * links when the link HREF contans certain substrings.
A:link[HREF*="ad."] IMG { display: none ! important }
A:link[HREF*="ads."] IMG { display: none ! important }
A:link[HREF*="/ad"] IMG { display: none ! important }
A:link[HREF*="/A="] IMG { display: none ! important }
A:link[HREF*="/click"] IMG { display: none ! important }
A:link[HREF*="?click"] IMG { display: none ! important }
A:link[HREF*="?banner"] IMG { display: none ! important }
A:link[HREF*="=click"] IMG { display: none ! important }
A:link[HREF*="/ar.atwo"] IMG { display: none ! important }
A:link[HREF*="spinbox."] IMG { display: none ! important }
A:link[HREF*="transfer.go"] IMG { display: none ! important }
A:link[HREF*="adfarm"] IMG { display: none ! important }
A:link[HREF*="bluestreak"] IMG { display: none ! important }
A:link[HREF*="doubleclick"] IMG { display: none ! important }
/* disable ad iframes */
IFRAME[SRC*="ad."]  { display: none ! important }
IFRAME[SRC*="ads."]  { display: none ! important }
IFRAME[SRC*="/ad"]  { display: none ! important }
IFRAME[SRC*="/A="]  { display: none ! important }
IFRAME[SRC*="/click"]  { display: none ! important }
IFRAME[SRC*="?click"]  { display: none ! important }
IFRAME[SRC*="?banner"]  { display: none ! important }
IFRAME[SRC*="=click"]  { display: none ! important }
IFRAME[SRC*="/ar.atwo"]  { display: none ! important }
IFRAME[SRC*="spinbox."]  { display: none ! important }
IFRAME[SRC*="transfer.go"]  { display: none ! important }
IFRAME[SRC*="adfarm"]  { display: none ! important }
IFRAME[SRC*="bluestreak"]  { display: none ! important }
IFRAME[SRC*="doubleclick"]  { display: none ! important }
/* turning some false positives back off */
A:link[HREF*="download."] IMG { display: inline ! important }
A:link[HREF*="click.mp3"] IMG { display: inline ! important }
A:link[HREF*="newthread"] IMG { display: inline ! important }
 * For more examples see http://www.mozilla.org/unix/customizing.html
/* block some flash */
 embed[type="application/x-shockwave-flash"][src*="spd.atdmt.com"] {
   display: none !important;
   visibility: hidden !important;
blink { text-decoration: none ! important }
marquee { -moz-binding: none ! important }
:link, :visited { text-decoration: underline ! important }
img[src^="*/ads/*"] { display: none ! important; }
__________________
This space for rent
  #3
Old 01-21-2004, 01:42 PM
ph34r's Avatar
HAL
Here's a screenie of the JL front page from Mozilla, using the adblocking in my above post. No messing with /etc/hosts or anything like that...
__________________
This space for rent
  #4
Old 01-21-2004, 02:08 PM
hlrguy's Avatar
Thanks for the tip. I like your method better. I copied and created
userContent.css, and put it into
/usr/local/mozilla/defaults/profile/chrome/
however, I am still seeing adds from ad.doubleclick.net
Where did you put yours?
hlrguy
__________________
My Linux Blog
  #5
Old 01-21-2004, 02:20 PM
ph34r's Avatar
HAL
It goes in your own mozilla folder ...
~/.mozilla/default/foo.slt/chrome
__________________
This space for rent
  #6
Old 01-21-2004, 03:54 PM
Beavbo Beavbo is offline
Perfectshunist
Thanks ph34r that might be one of the neatest tricks I've seen to date!
Just out of curiosity though, what would you add to the userContent.css file in order to get it to stop showing those ibm.com/open flash animations? All i can get from the source of the page is its getting referred to by www.justlinux.com/RealMedia/ads, but I can't seem to block that correctly. Please post back if you have the inclination.
__________________
If you can't dazzle them with brilliance............riddle them with bullets
  #7
Old 01-21-2004, 03:57 PM
ph34r's Avatar
HAL
Playing with the src URL in :
Should do it...
__________________
This space for rent
  #8
Old 01-21-2004, 04:00 PM
Perfectshunist
Yea, thats where I tried changing it to www.justlinux.com/RealMedia but to no avail. I'll keep messing around with it and post should I figure it out. Thanks
__________________
  #9
Old 01-21-2004, 04:20 PM
Hayl's Avatar
Hayl Hayl is offline
add this - it should stop the rest:
/* remove Ads */
*[src*="mds.centrport.net"],
*[src*="images.deviantart.com/shared/topads.gif"],
*[src*="view.atdmt.com"],
*[src*="www.justlinux.com/RealMedia/ads/click_lx.ads/intm/linux/www.justlinux.com/index/706227077/468x60-2/House_Dealtime_Promotion_1e/dealtime_750_2.html/38653$
*[src*="www.justlinux.com/RealMedia/ads/Creatives/House_Dealtime_Promotion_1e/bg-left.gif"],
*[src*="www.justlinux.com/RealMedia/ads/Creatives/House_Dealtime_Promotion_1e/sp.gif"],
*[src*="www.justlinux.com/RealMedia/ads/Creatives/Hoovers_Online_4e"],
*[src*="www.justlinux.com/index/1238038594/house_ribbon/House_Ent_Linux_Fall03_1n/elforumsave-03.gif"],
*[src="www.justlinux.com/index/1238038594/house_ribbon/House_Ent_Linux_Fall03_1n/elforumsave-03.gif"],
*[src="http://www.justlinux.com/RealMedia/ads/click_lx.ads/intm"],
*[src="http://www.justlinux.com/RealMedia/ads/click_lx.cgi"],
*[src="http://www.justlinux.com/RealMedia/ads/Creatives/Nortel_Networks_Email_1b/sp.gif"],
*[src="http://www.justlinux.com/RealMedia/ads/Creatives/Nortel_Networks_Email_1b/right-bg.gif"],
*[src*="hardwarecentral.dealtime.com"],
*[src*="http://http.edge.ru4.com/smartserve"],
*[src*="www.justlinux.com/RealMedia/ads/Creatives/House_Dealtime_Promotion_1e/go.gif"],
*[src*="www.justlinux.com/RealMedia/ads/Creatives/House_Dealtime_Promotion_1e/logo.gif"],
*[src*="www.justlinux.com/RealMedia/ads/Creatives/House_Dealtime_Promotion_1e/bg-right.gif"],
*[src*="www.justlinux.com/icom_includes/special/cdxpo/80211-ribbon.gif"],
*[src*="www.justlinux.com/icom_includes/"],
*[src*="www.justlinux.com/RealMedia/ads/click_lx.ads/intm/linux/www.justlinux.com/"],
*[src*="www.internet.com/corporate/"],
*[src*="http://hosting.verio.com/index.php/vpsmanaged_vps.html"],
*[src*="hardwarecentral.dealtime.com/BannerIn"],
*[src*="www.verisign.com/images/landing/lan6031/ecom_form_160x209.gif"],
*[src*="hardwarecentral.dealtime.com/xKW-"],
*[src*=".qz3.net"],
*[src*="ads.pointroll.com"],
*[src*="mirror.pointroll.com"],
*[src*="www.justlinux.com/RealMedai"],
*[src*="a.tribalfusion.com"],
*[src*="/icom_includes/special/cdxpo/cdxpo-top.gif"],
*[src*="fmads.osdn.com"],
*[src*="www.justlinux.com/icom_includes/special/cdxpo/cdxpo-top.gif"],
*[src*="www.justlinux.com/icom_includes/special/cdxpo/"],
*[src*="/icom_includes/special/cdxpo/80211-ribbon.gif"],
*[src*="www.tinyminds.org/images/banners"],
*[src*="images/banners"],
*[src*="adfarm.mediaplex.com"],
*[src*="images.deviantart.com/affiliates/"],
*[src*="images.deviantart.com/shared/winzip.gif"],
*[src*="www.justlinux.com/RealMedia/ads"],
*[src*="images.deviantart.com/banners/"],
*[src*="images.deviantart.com/shared/trillian.gif"],
*[src*="sfads.osdn.com"],
*[src*="ads.doubleclick.com"],
*[src*="cache.burstnet.com"],
*[src*="ads.doubleclick.net"],
*[src*="ad.doubleclick.net"],
*[src*="ad.doubleclick.com"],
*[src*="us.a1.yimg.com"],
*[src*="www.theregister.co.uk/media"],
*[src*=".qz3.net"],
*[src*="a207.p.f.qz3.net"],
*[src*="a207.p.f.qz3.net/7/207/2554/v001/eyewonder.download.qz3.net/2554/114720"],
*[src*="/RealMedia/ads"],
*[src*="www.burstnet.com"],
*[src*="/ads"],
*[src*="ar.atwola.com"],
*[src*="spd.atdmt.com"] {
        display: none;
        visibility: hidden;
  #10
Old 01-21-2004, 05:15 PM
mdwatts's Avatar
mdwatts mdwatts is offline
Grand Master
Neato !!
Thank-you gentlemen as all of those now work great with Firebird.
__________________
  #11
Old 01-21-2004, 05:32 PM
Perfectshunist
Hooray, its working now! Apparently one of the tricks was I had to put it in the .phoenix/default/foo.slt/chrome/ directory (just like you said) unlike the .mozilla/default/foo.slt/ directory like my inner idiot was telling me to do
Basically I just compiled ph34r and Hayl's config files into one and put it in that directory and it works like a champ. In that code that Hayl posted, however, for me, the line that read:
needed to be changed to:
*[src*="www.justlinux.com/RealMedia/ads/click_lx.ads/intm/linux/www.justlinux.com/index/706227077/468x60-2/House_Dealtime_Promotion_1e/dealtime_750_2.html/38653$"],
For whatever reason, it was missing that last little bit of formatting. Anyway, thanks again guys, keep up the good work.
__________________
  #12
Old 01-21-2004, 05:54 PM
hlrguy's Avatar
So now, how do I change the title to 'How ph34r 86ed the adserver delays'?
hlrguy
__________________
My Linux Blog
  #13
Old 02-12-2004, 11:29 AM
ph34r's Avatar
HAL
New one... you can add one of the iframe lines to block stuff from www.verisign.com to get rid of that new big add on the right...
__________________
This space for rent
  #14
Old 02-12-2004, 12:15 PM
Hayl's Avatar
Has anyone been able to remove this text-based part of an Ad yet?
I haven't been able to figure it out.
This is a trimmed screenshot of what the part that is getting through the userContent.css filter looks like:
<edit> NM: found it - just add hotjobs in as a filter </edit>
  #15
Old 02-12-2004, 12:37 PM
Hayl's Avatar
the only ones I am getting now are the Nortel one and the Voice Over IP one
if you have a filter for them plz let me know.
Reply
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Help File Library
Modems
Command Reference
Hardware
Webservers
Software
More
internet.com
IT
Developer
Internet News
Small Business
Personal Technology
Search internet.com
Advertise
Corporate Info
Newsletters
Tech Jobs
E-mail Offers
internet.commerce
Be a Commerce Partner
Linux is a trademark of Linus Torvalds.
Acceptable Use Policy
The Network for Technology Professionals
Search:
About Internet.com
Legal Notices, Licensing, Permissions, Privacy Policy.
Advertise | Newsletters | E-mail Offers
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
